Installing a module with 5.2 SP1
I've created a zip file module and added an epidata export to utils/setup.
When I use this module with Deployment Centre to update a new site I get an error below.  Anyone now what might be wrong?  I'm guess it might be becuase the export file contains pages and I was not asked to specify the root page for importing them.
Importing Util\setup\ExportedFile.episerverdata
An error has occured and the transaction will be rolled back
Rolledback
An unhandled error has occured:
Exception: Parameter has no page set
Parameter name: pageLink[]
When executing
At C:\Program Files\EPiServer\CMS\5.2.375.133\Install\System Scripts\Install ZI
P Module.ps1:130 char:20
+ Add-EPiServerData <<<< -ImportSource $importFilePath `
Error - System.Management.Automation.CmdletInvocationException: A bulk installation has not been started ---> System.ApplicationException: A bulk installation has not been started
at EPiServer.Install.InstallationManager.RollbackBulkInstall()
at EPiServer.Install.Common.Cmdlets.RollbackBulkInstallCmdlet.ProcessRecord()
at System.Management.Automation.Cmdlet.DoProcessRecord()
at System.Management.Automation.CommandProcessor.ProcessRecord()
at System.Management.Automation.Internal.PipelineProcessor.SynchronousExecuteEnumerate(Object input, Hashtable errorResults, Boolean enumerate)
at System.Management.Automation.Parser.PipelineNode.Execute(Array input, Pipe outputPipe, ArrayList& resultList)
at System.Management.Automation.Parser.StatementListNode.Execute(Array input, Pipe outputPipe, ArrayList& resultList)
#27887
Feb 12, 2009 3:15
The ZIP-installer assumes the site has a start page, thats where it will import the pages. Does the site have a start page ?
#27907
Feb 12, 2009 15:54
