Control custom tab visibility
Is there a way for me to control the visibility of a custom tab based on the page type in Edit Mode. For example, I have a custom tab names External sources which is associated with a page type called referecences. If the page type is not this one, I would like to hide it.
#35169
Nov 30, 2009 16:38
Yes, you can implement the interface EPiServer.PlugIn.ICustomPlugInLoader and then do like this
// Hide/show tab
        public PlugInDescriptor[] List()
            PlugInDescriptor[] descriptors = null;
            // Check if we should show the plugin
            if (CurrentPage.PageTypeID == Utils.Settings.PageTypePressRelease || CurrentPage.PageTypeID == Utils.Settings.PageTypeFinancialReport)
                descriptors = new PlugInDescriptor[1];
                descriptors[0] = PlugInDescriptor.Load(this.GetType());
            // else return null
            return descriptors;
Magic, huh? :)
#35172
Nov 30, 2009 17:22
It is magic, but where so I implement this?
#35209
Nov 30, 2009 23:56
As Erik mentioned, implement the ICustomPlugInLoader interface for your tab-plugin to be able to decide if you want to create a plug-in or not for the current page. See the following example from the forms posting plug-in:
    [GuiPlugIn(DisplayName = "XFormdata",
                Description = "Show xformdata",
                Area = PlugInArea.EditPanel,
                UrlFromUi = "edit/XFormPostings.ascx",
                LanguagePath = "/edit/formpostings",
                RequiredAccess = AccessLevel.Edit)]
    public partial class XFormPostings : UserControlBase, ICustomPlugInLoader
            if (!PageContainsFormProperties())
                return new PlugInDescriptor[] { };
            else
                return new PlugInDescriptor[] { PlugInDescriptor.Load(typeof(XFormPostings)) };
Linus Ekström
#35295
Dec 03, 2009 9:25
Thanks perfect! It works like magic!
#35311
Dec 03, 2009 15:42
