Strange multilanguage behavior
I got a strange behavior in our multilanguage solution where we have NO, DK and DE as languages. when you type in the one of the urls (eks: www.xxx.NO) it sometimes comes up with the DK or the DE site, but if you keep hitting refresh it finally goes to the NO site in the end. the same happens if you try to go from either of DK, DE or NO.
 we have in our <siteHosts> in web.config:
<add name="xxx.de" language="de" />
  <add name="www.xxx.de" language="de" />
<add name="xxx.no" language="no" />
  <add name="www.xxx.no" language="no" />
<add name="xxx.dk" language="dk" />
  <add name="www.xxx.de" language="dk" />
 We only have one sitesettings.
Anyone seen this before?
#33285
Oct 07, 2009 9:27
 I know that we had a bug in the first EPiServer CMS 5 release where this behaviour would sometimes appear. The bug has been fixed altough I'm not 100% sure what version the fix was included in. In which version are you experiencing the problem?
Regards
Linus Ekström
EPiServer Development Team
#33287
Oct 07, 2009 9:58
We have a registered bug related to this issue. This bug was registered for CMS 5 R2 SP2 specifically.
Bug #26828: Sitehosts settings and cache
There is hotfix for this issue.Contact EPiServer Support for the hotfix
#33291
Oct 07, 2009 10:45
We are upgrading the solution from EPiServer 6 (not R2) to EPiServer 7, and after upgrade and deploying to production it looks like we have almost the same behavior as Kjetil described:
For example, I open xxx.com and see content in English; in another browser I open xxx.se and there I also see content in English.
After some period (about 2 minutes) I refresh xxx.se and see content in Swedish. Then I refresh xxx.com - and there I see content in Swedish too.
Can anyone help with this?
#80754
Jan 31, 2014 9:28
Do you have output caching turned on?
If so the default behaviour for asp.net output caching is to cache for Path part (note that host is not part of Path), that is the Startpage will be cached for path "/" for all startpages will be output cached for same path.
If you set attribute in httpCacheVaryByCustom=host on element applicationSettings in episerver.config then the output cache should take host into consideration during output caching.
#80759
Jan 31, 2014 11:39
Thanks Johan, you sent me the right way :) The problem was in output cache on StartPage.
#80770
Jan 31, 2014 13:25
