Robots.txt for different sites
Hi All,
I have a EPi server web application. The same web application is hosted under 3 domains.  Now my requirement is to have diffrenet Robots.txt for different domains. But since all the domains are pointing to sane folder I can have only file placed in that folder. Is there any workaround for placing seperate Robots.txt file under each domain.
Thanks in Advance.
#33163
Oct 03, 2009 11:03
You can create 3 files:
robotsDomain1.txt
robotsDomain2.txt
robotsDomain3.txt
and then define your own handler, assign it to robots.txt in web.config
<httpHandlers>
<add verb="*" path="robots.txt" type="Project.RobotsHandler"/>
</httpHandlers>
and inside the handler check Request.Url.DnsSafeHost and return the content of one of the files.  If you use IIS7 you define handlers in section
<system.webServer>
<handlers>
<add name="robots" path="robots.txt" verb="*" type="Project.RobotsHandler, Project" />
</handlers>
</system.webServer>
#33165
Oct 03, 2009 11:14
Thanks for your reply.
Can you point me to any URL that explains the code to be written in the Handler.
#33166
Oct 03, 2009 11:39
http://www.kleenecode.net/2007/11/17/dynamic-robotstxt-with-aspnet-20/
#33167
Oct 03, 2009 12:11
Thanks Maras. Below link is also usefull
http://www.atlasbay.com/2008/11/06/robotstxt-httphandler-in-iis7/
Thanks for your suggestion.
#33168
Oct 03, 2009 12:25
