XForm not submitting
Hi there,
This was the first time that I have added a XForms template in CMS5 - as our other websites that have XForms are CMS4 - therefore I don't have a working example.
I downloaded the Public Package with the Xforms template example and the Xform is displayed correctly - however when the submit button is clicked (which is setup to send an email and then redirect to another page) it doesn't work, it just performs a postback.
The event that is assigned to the AfterSubmitPostedData property of the FormControl is not fired when the button is clicked - the button does however cause a postback. The FormControl.FormDefinition.IsSent property after the submit button is clicked is false which is why I presuming the AfterSubmitPostedData event isn't triggered?
Below is the definition of the submit button:
<input class="xFormButton" type="submit" onclick="WebForm_DoPostBackWithOptions(new WebForm_PostBackOptions("ctl00$ctl00$ContentPlaceHolderContent$ContentPlaceHolderContent$XForm1$FormControl$ctl00", "", true, "", "", false, false))" name="ctl00$ctl00$ContentPlaceHolderContent$ContentPlaceHolderContent$XForm1$FormControl$ctl00" value="Submit Query"/>
Any help would be appreciated Smile
#26966
Jan 11, 2009 23:29
Are you sure the problem isn't in your smtp settings?
 /Mattias
#26971
Jan 12, 2009 10:59
You don't have a field that you've set to be required but is empty?
#26977
Jan 12, 2009 15:31
or maybe the javascript function WebForm_DoPostBackWithOptions dosnt exists. check the rest of your html code. Have happened me when I was a bit to clever with some cacheing :)
If the  javascript isnt there you can as a quick fix add a asp:Linkbutton in your masterpage. that will add javascript function.
#26982
Jan 12, 2009 19:58
Hi there,
 thanks for the responses - as it turns out it was my SMTP settings, thanks Mattias.
#26984
Jan 13, 2009 3:33
