There is not a specific Javascript document except for what you find in the sdk.
Our Javascript developer wrote this article which helps a bit,
http://world.episerver.com/en/Articles/Items/Modal-Dialogs-in-the-EPiServer-UI-for-non-IE-Browsers/
Otherwise I would recommend searching for that info, looking at our blog posts and the rest of the articles at this website.
We know its a little bit difficult to find the correct information and we are continuing working on to improving it. :-)
Sadly there is no documentation on the Editor javascript API, I would have loved it when I started at EPiServer. However I might be able to push you in the right direction if you describe what you want to do and what you are after.
/Regards
Henrik
I was trying to create a HTML construct;
<p class="vcard">
<span class="fn org">Example Corp</<span><br />
<span class="adr">
<span class="street-address">123 Somewhere Road</span><br />
<span class="locality">Sunderland</span><br />
<span class="country-name">United Kingdom</span>
</span>
</p>
from a editor plugin and then re-populate the control if the editor selected some or all of the HTML.
I used this to select the parent node of the selected content:
var range = plugin.editorDocument.selection.createRange();
parent = range.parentElement();
while (parent.className != "vcard")
parent = parent.parentElement;
if (parent.tagName == "body")
parent = null;
break;
}And then iterated through the nodex within the parent node to get the values. When I started I was wondering if there was a simpler way? I didn't know if there where eisting JavaScript functions available within the editor that would have done alot of what I wanted to do?
Got it working now, but I'm sure I've repeated alot of code that already exists.
Jim.
I have now re factored my editor plugin to follow the new CMS 5 way of doing things described in the article Modal Dialogs in the EPiServer UI for Non-IE Browsers (http://world.episerver.com/en/Articles/Items/Modal-Dialogs-in-the-EPiServer-UI-for-non-IE-Browsers/).
I have one small thing, how do you get the call to EPi.AddEventListener to work? I have added a script tag pointing to /UI/javascript/system.js, which is loading correctl, but that method does not seam to exist. Also, when I look at the source of the system.js, there is no definition for AddEventListener either.
The editor window inherits straight from System.Web.UI.Page.
Am I missing something? Is there another js file I need to include?
Jim.
The needed javascript files (and css for cms look) will automatically be registered if you use UI/MasterPages/EPiServerUI.Master master page file and inherit from EPiServer.UI.SystemPageBase.
If you want to register the files yourself the needed files are:
About editor API: There really aren't that much helper functions in the API. There is one file Util/Editor/Javascript/HtmlTextBox2_API.js which contains some code you might find useful. But since it really has no comments(!?) it is a bit hard to see what to use. I had a hard time myself to understand what was going on...
I have made some additions to this file in EPiServer CMS 5 to overcome some of the bugs in the old editor (and/or MS HTML Edit bugs) and you might find EPiGetRangeParent useful since range.parentElement() returns wrong parentElement when the user has made certain types of selections.
/Regards
Henrik
Great, got it working now.
It was the UI/javascript/system.js file I was missing.
Jim
I'm trying to build editor plugin to allow users to create an address block using the VCard microformat.
I have been following the Create an editor Plug-In tutorial (http://sdk.episerver.com/library/CMS5/Developers%20Guide/How%20To/Create%20an%20editor%20Plug-in.htm?id=24896), however there are things I want to do that aren't descibed in here.
I was wondering if the javascript API for the editor environment is documented anywhere?
There must be loads of JavaScript functions available that provide alot of the functionality that I will want, however, I don't really want to have to debug the existing editor functionality to fnd it.
Jim
