Demo Code - Blogs
Anyone any idea why i'm getting errors like the error below from the demo code when using Blogs.
It seems to be originating from the EPiServer.Blog.dll which is looking for two files which aren't in the solution. These files are
/xmlrpc/Manifest.aspx and /xmlrpc/rsd.aspx
Should this folder (xmlrpc) have been installed with the Demo code?
System.Web.HttpException: The file '/xmlrpc/Manifest.aspx' does not exist.
at System.Web.UI.Util.CheckVirtualFileExists(VirtualPath virtualPath)
at System.Web.Compilation.BuildManager.GetVPathBuildResultInternal(VirtualPath virtualPath, Boolean noBuild, Boolean allowCrossApp, Boolean allowBuildInPrecompile)
at System.Web.Compilation.BuildManager.GetVPathBuildResultWithNoAssert(HttpContext context, VirtualPath virtualPath, Boolean noBuild, Boolean allowCrossApp, Boolean allowBuildInPrecompile)
at System.Web.Compilation.BuildManager.GetVirtualPathObjectFactory(VirtualPath virtualPath, HttpContext context, Boolean allowCrossApp, Boolean noAssert)
at System.Web.Compilation.BuildManager.CreateInstanceFromVirtualPath(VirtualPath virtualPath, Type requiredBaseType, HttpContext context, Boolean allowCrossApp, Boolean noAssert)
at System.Web.UI.PageHandlerFactory.GetHandlerHelper(HttpContext context, String requestType, VirtualPath virtualPath, String physicalPath)
at System.Web.UI.PageHandlerFactory.System.Web.IHttpHandlerFactory2.GetHandler(HttpContext context, String requestType, VirtualPath virtualPath, String physicalPath)
at System.Web.HttpApplication.MapHttpHandler(HttpContext context, String requestType, VirtualPath path, String pathTranslated, Boolean useAppConfig)
at System.Web.HttpApplication.MapHandlerExecutionStep.System.Web.HttpApplication.IExecutionStep.Execute()
#22832
Aug 18, 2008 15:19
It turns out we've been using the RC1 release of the Demo Templates which doesn't include these files.
The latest version R1 of the demo templates does include these files so we'll upgrade to that one.
#23326
Sep 03, 2008 12:14
