Scheduled job not shoving in backend
Hey.
Im working on a scheduled job in episerver  5.1.422.256
The problem is that i cant see it in the admin backend. the code is a simple textbook example.
using EPiServer.DataAbstraction;
using EPiServer.PlugIn;
namespace Primera.CompaireMeta
ScheduledPlugIn(
DisplayName = "Sync travelbook and EPi meta",Description =
"Sync script ",
SortIndex=200)
public class TravelbookEPiSync
public static string Execute()
return System.DateTime.Now.ToString();
 I tested this no another local machine installation with the same episerverdatabase, and here it is not shown either.
I tested this on an site i have with 5.1.422.122 where it shows up  with out any problem.
I tried to install the task manually, and by placing breakpoints, i could see that the code did get called atleast once, but still i could not see the taks in the admin mode.
Has any of you had a simular problem, or have any idea how and what can bee done.
best regards
Andreas
#22193
Jul 28, 2008 11:19
