PropertyPageReference Hyperlink
Ok, so this might be a longshot, but: In previous versions we've used the following code to alter the output from pageref-propertys, but now with CMS 5 pageLink always ends up as null, which implies that PropertyPageReference isn'nt compatible with HyperLink. Does somebody know why, and maybe have a suggestion for a workaroud?
        protected override void AddedControl(System.Web.UI.Control control, int index)
            try
                switch(this.InnerProperty.GetType().ToString())
                    case "EPiServer.Core.PropertyPageReference" :
                        base.AddedControl(control, index);
                        HyperLink pageLink = control as HyperLink;
                        if(pageLink != null)
                               //do stuff with pageLink here
                    break;
#19305
Apr 02, 2008 17:21
Would like to know the same thing.
I want to be able to edit the Link Text that is being rendered (in some cases it needs to be different from PageName).
#35310
Dec 03, 2009 15:03
