Strange errors
The current template does not match the specified page type file Server Error in '/' Application. [EPiServerException: The current template does not match the specified page type file] EPiServer.PageBase.ValidatePageTemplate() +735 EPiServer.PageBase.OnInit(EventArgs e) +522 EPiServer.TemplatePage.OnInit(EventArgs e) +96 System.Web.UI.Control.InitRecursive(Control namingContainer) +321 System.Web.UI.Page.ProcessRequestMain(Boolean includeStagesBeforeAsyncPoint, Boolean includeStagesAfterAsyncPoint) +834 Just randomly, very few times appear when the the search is used (?quicksearchquery=). Any idea what this might be? And also, when people are trying to surf using e.g. a Playstation 3 or a Cellphone, this message pops up: Cannot use a leading .. to exit above the top directory. [HttpException (0x80004005): Cannot use a leading .. to exit above the top directory.] System.Web.Util.UrlPath.ReduceVirtualPath(String path) +3626102 System.Web.Util.UrlPath.Reduce(String path) +84 System.Web.Util.UrlPath.Combine(String appPath, String basepath, String relative) +326 System.Web.HttpResponse.ApplyAppPathModifier(String virtualPath) +209 System.Web.UI.HtmlControls.HtmlForm.GetActionAttribute() +2036998 System.Web.UI.HtmlControls.HtmlForm.RenderAttributes(HtmlTextWriter writer) +840 System.Web.UI.HtmlControls.HtmlControl.RenderBeginTag(HtmlTextWriter writer) +39 System.Web.UI.HtmlControls.HtmlForm.Render(HtmlTextWriter output) +56 System.Web.UI.Control.RenderControlInternal(HtmlTextWriter writer, ControlAdapter adapter) +25 System.Web.UI.Control.RenderControl(HtmlTextWriter writer, ControlAdapter adapter) +121 System.Web.UI.HtmlControls.HtmlForm.RenderControl(HtmlTextWriter writer) +37 System.Web.UI.Control.RenderChildrenInternal(HtmlTextWriter writer, ICollection children) +199 System.Web.UI.Control.RenderChildren(HtmlTextWriter writer) +20 System.Web.UI.Control.Render(HtmlTextWriter writer) +7 System.Web.UI.Control.RenderControlInternal(HtmlTextWriter writer, ControlAdapter adapter) +25 System.Web.UI.Control.RenderControl(HtmlTextWriter writer, ControlAdapter adapter) +121 System.Web.UI.Control.RenderControl(HtmlTextWriter writer) +22 System.Web.UI.Control.RenderChildrenInternal(HtmlTextWriter writer, ICollection children) +199 System.Web.UI.Control.RenderChildren(HtmlTextWriter writer) +20 System.Web.UI.Page.Render(HtmlTextWriter writer) +26 System.Web.UI.Control.RenderControlInternal(HtmlTextWriter writer, ControlAdapter adapter) +25 System.Web.UI.Control.RenderControl(HtmlTextWriter writer, ControlAdapter adapter) +121 System.Web.UI.Control.RenderControl(HtmlTextWriter writer) +22 System.Web.UI.Page.ProcessRequestMain(Boolean includeStagesBeforeAsyncPoint, Boolean includeStagesAfterAsyncPoint) +2558
#13369
Feb 26, 2008 8:52
