Run a scheduled job as a specific user in 4.62B
I've read about how to run a scheduled job as a specific user in CMS 5 (http://labs.episerver.com/en/Blogs/Ted-Nyberg/Dates/112276/8/Run-a-scheduled-job-as-a-specific-EPiServer-user/), and need to know how to do this in 4.62B (.NET 2.0).
How is this done?
Jakob
#26381
Dec 03, 2008 10:47
Look at this FAQ.
http://world.episerver.com/en/FAQ/Items/How-do-I-save-a-page-as-an-anonymous-user/
The logic you need is there (you just need to reverse it).
/Steve
#26387
Edited, Dec 03, 2008 12:47
Thanks for your reply!
Unfortunately I get the following compilation error:
Keyword 'this' is not valid in a static property, static method, or static field initializer
An object reference is required for the nonstatic field, method, or property 'EPiServer.PageBase.CurrentUser.get'
Code Example:
public class ExportOrders : TemplatePage
public static string Execute()
System.Security.Principal.IPrincipal principal = AuthenticationProvider.Authenticate(this, "username", "password");
CurrentUser = principal as UnifiedPrincipal;
#26398
Dec 04, 2008 9:08
From the Stacktrace (NullException on Order.Load):
 " at EPiStore.AttributeFactory.ᐁ()\r\n at EPiStore.AttributeFactory.GetAttributeSettings(PageData itemPage)\r\n at EPiStore.DataAbstraction.CartItem..ctor(Int32 pageID, Int32 quantity, Double price)\r\n at EPiStore.DataAbstraction.CartItem..ctor(Int32 pageID)\r\n at EPiStore.DataAbstraction.OrderItem..ctor(Int32 pageID)\r\n at EPiStore.DataAbstraction.Order.ᐁ(DataSet )\r\n at EPiStore.DataAbstraction.Order.ᐁ(DataSet )\r\n at EPiStore.DataAbstraction.Order.Load(Int32 id)\r\n at KnowIT.Shop.Core.ExportOrders.Execute()"
#26479
Dec 08, 2008 10:19
You are calling Authenticate() from a static method, therefor you can not use "this" as a parameter. Try to use something else, eg "new ExportOrders()".
#26481
Dec 08, 2008 11:39
Thanks for the suggestion.
Even if I make that change, I still get en error message for CurrentPage (for the same reason, since I'm using a static method):
Is it possible to create an instance of the ExportOrders class (from inside the static method Execute()), and run the Scheduled Job through that?
#26483
Dec 08, 2008 14:41
Try to set System.Threading.Thread.CurrentPrincipal instead of CurrentUser.
#26514
Dec 09, 2008 9:35
Thanks, Erik, but I still get the same error message, and the EPiServer Support seems to have given up on this issue.
More ideas are greatly appreciated! :)
Jakob
#26637
Dec 15, 2008 11:17
Where do you use CurrentPage here? You cannot use CurrentPage in a scheduled task. There is no request, no HttpContext, no template and no current page :-)
/steve
#26641
Dec 15, 2008 11:55
Hi Steve!
I'm not using CurrentPage, I'm using the method Load in the class Order (EPiStore), which deep down is fetching properties from the product (which is a Page), and there is my problem.
Since there is no overloaded version of Order.Load, I can't edit the accesslevel.
Best Regards
Jakob
#26647
Dec 15, 2008 13:36
Ah, hm, bummer.
And you have tried setting Thread.CurrentPrincipal to a known Principal with the needed access rights? Cause that is the one used to check for access rights.
You should be able to create a UnifiedPrincipal with an UserSid object (UserSid.Load(...)).
/steve
#26655
Dec 15, 2008 15:06
Steve has the working solution for EPiServer 4, along with earlier mentioned, this works:
System.Security.Principal.IPrincipal principal = AuthenticationProvider.Authenticate(new YourClassThatYouAreInNow(), "user", "password");
Thread.CurrentPrincipal = principal as UnifiedPrincipal;
/ Jacob
#45001
Edited, Oct 26, 2010 10:31
