Iterating through the contents of UFS folder
Using the GetFiles() method of the unified file system I want to create an image gallery. As part of the gallery I need to implement pagination. Has anyone done this or knows of teh most effecient way to retrieve a subset of collection returned from getFiles()?
Thanks in advance
#25873
Nov 11, 2008 0:11
Just a quick note, and not an answer to your question:
 If you are creating an image gallery, you should take look at the existing free module at Epicode. Have a look here:
https://www.coderesort.com/p/epicode/wiki/PictureGallery
Lars Øyvind Bodahl
www.epinova.no
#25877
Nov 11, 2008 8:11
The module includes code to implement pagination and it uses a repeater to display the images.
It uses the following code to retrieve all images in a folder:
UnifiedDirectory dir = System.Web.Hosting.HostingEnvironment.VirtualPathProvider.GetDirectory(filePath) as UnifiedDirectory;
unsortedFiles = dir.GetFiles(); ArrayList arrayListSorted = new ArrayList(unsortedFiles); //creating arraylist with the pic, and do a sorting with
allFiles = (UnifiedFile[])arrayListSorted.ToArray(typeof(UnifiedFile));
Lars Øyvind Bodahl
www.epinova.no
#25878
Edited, Nov 11, 2008 8:22
GetFiles() returns an array of UnifiedFile - LINQ is great when you want to retrieve a subset of that array. (if you're on the correct .NET version that is.. :-))
UnifiedFile[] files = directory.GetFiles();
// First X elements:
var tenFirst = files.Take(10);
// Skip X element before taking Y elements.
var nextTen = files.Skip(10).Take(10);
/magnus
#25914
Edited, Nov 12, 2008 7:01
#25944
Nov 13, 2008 13:10
Thanks Magnus.
LINQ looks perfect, however when I use Take(10) on a collection of 14 I get a null collection back, have you had any issues with the unfiedCollection like this?
Regards,
Ian
#25945
Nov 13, 2008 13:11
