Extending Unified File
I want to extend/inherit from the UnifiedFile class to add some extra properties and encapsulate the functionality in my project
However upon doing so e.g.
ImageItem : UnifiedFile
I get the error no constructor exists with 0 arguments. I do not really need all the extraneous info associated with the default constructor is there a way round using it?
Has anyone implemented something similiar and has some advice?
Thanks a lot
#25891
Nov 11, 2008 12:39
Hi Ian,
I'm not sure that inheriting from UnifiedFile is such a good idea.  The problem is that none of the methods in EPiServer are going to give you back an instance of an ImageItem, so even if you construct a UnifiedFile object you'll be unable to get it back unless you explicitly construct a new ImageItem and initialize it with the data from the UnifiedFile returned from EPiServer.
I'd suggest instead creating a wrapper class for UnifiedFile, like this:
public class ImageItem
public UnifiedFile UFile { get; private set; }
public ImageItem(UnifiedFile file)
UFile = file;
#region Utility Methods that operate on UFile, specific to ImageItem
#endregion
Then you can easily turn any UnifiedFile in to an ImageItem.
Hope this is useful.
Andy
#25894
Edited, Nov 11, 2008 12:56
Hi Andy,
I was imagining that might be the way to go.
Thanks for the confirmation
Ian
#25909
Nov 11, 2008 17:54
