Loading www.mysite.com results in the error below, byt www.mysite.com/en works fine. Anyone that have come across the same problem before?
Object reference not set to an instance of an object.
Exception Details: System.NullReferenceException: Object reference not set to an instance of an object.
Source Error:
Stack Trace:
System.Web.HttpContext.RewritePath(VirtualPath filePath, VirtualPath pathInfo, String queryString, Boolean setClientFilePath) +40
System.Web.HttpContext.RewritePath(String filePath, String pathInfo, String queryString, Boolean setClientFilePath) +51
EPiServer.Web.UrlRewriteModuleBase.BeginRequestEventHandler(Object sender, EventArgs e) +585
System.Web.SyncEventExecutionStep.System.Web.HttpApplication.IExecutionStep.Execute() +92
System.Web.HttpApplication.ExecuteStep(IExecutionStep step, Boolean& completedSynchronously) +64
