For clarification: I can successfully log in to the webservice DataFactoryService.asmx with the same username/password in the Windows authentication form so I know the username/password are correct.
Here are more details of the error:
{"System.Web.Services.Protocols.SoapException: Server was unable to process request. --->
EPiServer.Core.AccessDeniedException: Access was denied to page 2166.\n at
EPiServer.DataFactory.GetDefaultPageData(PageReference parentPageLink, Int32 pageTypeID, ILanguageSelector selector, AccessLevel access)\n at
EPiServer.DataFactory.GetDefaultPageData(PageReference parentPageLink, Int32 pageTypeID, AccessLevel access)\n at
EPiServer.DataFactory.GetDefaultPageData(PageReference parentPageLink, Int32 pageTypeID)\n at
EPiServer.WebServices.DataFactoryService.GetDefaultPageData(PageReference pageLink, Int32 pageTypeID)\n
--- End of inner exception stack trace ---"} Hope this helps,
Chris
Hi Guys,
I'm getting a AccessDeniedException when using the DataFactoryService to grab data from an EPiServer 4.6 site. The web service directory has been set up just to allow BasicAuthentication on a Windows user and local policy rights have been set up correctly following from this link : http://world.episerver.com/en/FAQ/Items/Why-do-I-get-access-denied-when-logging-on-using-a-Windows-Account-even-if-I-am-an-administrator/
If I run a GetPage() or GetChildren() method then it will just return me a AccessDeniedException saying I do not have the correct access level even though I should be Administrator as I'm logged in with a Windows authenticated user account.
I can run the Ping() method which comes back as true so I know that I am authenticated correctly.
Any help would be great,
Kind Regards,
Chris
