Flash movie in editor
It seems (EPi 4.61 , ASP 2) that EPi editor sometimes changes the html used to insert flash. For example the "play" param value is set to "0" occasionally Is this possible to turn off? I also want to add Javascript in the editor to run flash ( to get rid of the IE "click to use and activate this control " bug) I guess it is better not to try this and use a separate flash template?
#13193
Sep 06, 2007 11:11
