Database Mirroring and Episerver
Hi, The mirroring functions in Episerver are a little bit limited and I'm thinking of using the database mirroring in sql server 2005, does it work with episerver? Has someone tried it? Thanks! /Frederic.
#13188
Sep 04, 2007 13:47
I use it and it's working. Just change your connection string to somthing like this:
#15511
Sep 05, 2007 13:20
Ok nice! My issue here is I don't want EPiserver to have access to both of the database but just one, was it it you meant too or are you using it to have one Episerver using two sql server? Thanks!
#15512
Sep 06, 2007 9:27
EPi only use the server that are principal, mor info on the database mirroring that I use can be found here http://www.microsoft.com/technet/prodtechnol/sql/2005/dbmirror.mspx
#15513
Sep 13, 2007 13:10
