Password recovery
I have forgotten the edit/admin login password (for administrator). What is the procedure to retrieve this? I've tried logging in with my Windows account - but that doesn't work either. There really should be a "forgott my username or password" link in the login picture, which sends the login credentials to my e-mail.
#13071
Jun 14, 2007 10:26
Hi. You should always be able to login in edit and admin with the local windows admininistrator account. -- Per
#15360
Jun 14, 2007 11:32
Let's assume I'm not able to log in with my Microsoft account. What then?
#15361
Jun 20, 2007 14:31
Hi. EPiServer 4 is configured so that you always can login with the local administrator account.
#15362
Jun 20, 2007 16:45
Hello again. To clarify, you need of course to have the location path in web.config for the admin catalog to include Administrators. E.g.
#15363
Jun 20, 2007 17:15
Why is that I cannot enter the Admin mode of the sample Alloy site?
I use the URL http://localhost:17000/your/relative/path/to/UI/MyEPiServerSite/Episerver , and a login page shows up.
What should be the username and password then??????
Anyone can help?
#69940
Apr 10, 2013 2:23
As Per writes above, you can login in with a local windows admininistrator account.
#69942
Apr 10, 2013 8:19
Thanks Mari.
I have soloved that.
#69944
Apr 10, 2013 8:49
If no logins work but you have access to web.config, you could always "break in" as Fredrik describes in this blog:
http://blog.fredrikhaglund.se/blog/2010/03/08/episerver-security-and-access-control-12/
Basically commenting out all the "<deny users="*" />" lines will let you log in without a password.
Quickly fix your password, then put web.config back the way it was.
Beware this should only be used in emergencies.
#70003
Apr 10, 2013 20:18
