Delete startpage language
Hello I added a new language to the default start page "Wellcome to episerver" and want to delete it, but "Delete language" option is disabled. The subpage languages can be deleted. Is there a way to delete default page language? What records have to be removed from the database? Thanks in advance.
#13037
May 10, 2007 13:34
Hi You're correct, the option to delete a language from the start page is disabled. The start page is handled as a special page, for instance are you not able to delete it. Whether or not you should be able to delete a language from the start page can be up for discussion, but in the current design you can't. I would not recommend doing anything directly in the database. Instead you can work around it by temporarily changing the sites start page to another page. Then go in and remove the language from the original start page. When that is done, set the start page back to the original one.
#15287
May 10, 2007 14:34
