Invalid XHTML output from editor
The XHTML string property generates invalid XHTML tags. The output is typically
instead of
, and instead of . Even if the XHTML is typed in correctly in code view, this is changed back to plain HTML by the editor. Pretty annoying. This typically generates a lot of validation errors from the published content, and makes the site look a lot worse than necessary. I was thinking of using EditX, but since this is a productoin environment I don't want to add none-releaset features...
#13048
May 22, 2007 10:13
It seems the old "XHTMLTemplatePage" override of the Render-method fixes most of the problems... One may of course extend this class with custom code to handle desired replacements: http://www.episerver.com/en/EPiServer_Knowledge_Center/Download2/Code-Samples/XHTML-and-Accessibility/5524/
#15315
May 29, 2007 12:00
