Broken Thumbnail Images
Does anyone have an idea of why the thumbnail images within the file manager appear broken? The thumbnail images are being created as they are sitting within ...\Util\temp\thumbcache\... Is there some form of permissions or reference issue to access the images?
#13042
May 21, 2007 1:57
The ASP.NET account (aspnet or Network Service) needs write access to the directory in order to generate the thumbnails. See the http://www.episerver.com/en/EPiServer_Knowledge_Center/Documentation/TechNotes/EPiServer-Operators-Guide/#File%20Access%20Rights for more information. /Steve
#15295
May 21, 2007 8:00
Just noticed that we are having the same problem. The thumbnails are being generated just fine under Util\Temp\thumbcache but when choosing Show thumbnails in the file manager we just get a broken image. Could it be that it's pointing to the wrong folder when showing thumbnails or something like that? Any help would be appreciated. /Martin
#15296
May 21, 2007 10:05
I'm pretty sure this is a permissions problem. I've never had - or heard of - a thumbnail cache problem that was not related to security. Try FileMon from System Internals to see if there are any permission problems with the files under /util/temp /Steve
#15297
May 21, 2007 10:44
OK, I've used Filemon to see if that can show anything that's wrong. Can't say I'm an expert at Filemon but I can see that it is requesting files from the thumbcache-folder and the result is always success, but still I can't see the pictures in the file manager. By the way, I'm using the Unified File System feature to store my files, if that can have anything to do with it? Best regards /Martin
#15298
May 21, 2007 13:17
I have also used filemon, which shows its successfully opening and reading the correct images in the correct directory, while attempting to load the thumbnails in the file manger. I have checked the ASP.Net permissions to the directory, and it has both read and write access. If the permissions is the issue how can it be able to create the thumbnail images? I would be grateful for any further ideas?
#15299
May 22, 2007 2:02
Just took one more look at this problem which I haven't been able to solve. Used Fiddler to see if that might give some more information, can't say I understand Fiddler that much but here is what happens. Checked the "Show thumbnails" checkbox and then the following URL gets called (for an image called hermes.jpg): /Util/Image.aspx?width=50&height=50&src=%2fDocuments%2fhermes.jpg. The response code is 200 (OK) but the content-type is "text/html" which seems a bit strange? If I take that URL and try to call it directly in a browser I just get gibberish in the web browser. Doesn't make much sense and I'd expect to get an image back when calling that url, isn't that correct? The image.aspx doesn't give much help either unfortunately since there is no code-behind file for that aspx in the EPi-project. Would really appreciate if someone could help us solve this issue. /Martin Emanuelsson
#15300
Jun 13, 2007 17:11
Richard and everybody else, Finally I believe I've managed to nail down this problem and what the cause for it is. I'm using ASP.NET AJAX on my site and for that to work with URL rewriting we've had to implement a HTTP Module which you can see here: http://www.episerver.com/en/EPiServer_Knowledge_Center/Developer-Forum2/EPiServer-Developer-Forums-/1805/10539/ Now I've noticed that this causes the thumbnails in the file manager to break, took a while (and quite some "filemon-ing" and "fiddler-ing") to realize this connection. To solve the problem I've changed the HTTPModule so that it only acts when the contenttype is "text/plain" and not "text/html". Perhaps this is something that you're using as well Richard? Perhaps there is another way to make both ASP.NET AJAX and the showing of thumbnails to work? If so I'm really interested to take part of it. Best regards Martin Emanuelsson Guide
#15301
Jun 28, 2007 18:19
Yes our solution does implement an http module also and we had also narrowed the problem down to this, however we hadn't determined how to resolve the conflict between the module and the thumbnails. Thanks for the info, we'll try it out. Rachel - Richard's colleague
#15302
Jun 29, 2007 4:46
