Admin mode plugin - How to create control to edit ImageURL property?
Hi, I'm working on a plugin for AdminMenu. It is used to create certain page structures. User has to fill in some TextBoxes and their values are assigned to properties of created pages. It's obvious how to deal with string properties, but one of the properties is of type Image Url. I would like to use this standard "Select Image" window with which you can select and upload pictures (the same that you have in edit mode). How it can be done? What to put into aspx file and what behind code is necessary? I could not find any example or doc on this. Thanks in advance, Mateusz
#13017
Apr 20, 2007 11:47
