Pagetree without header?
Question nr 2: I have a pagatree menu, and sometimes there is no results in the list but still I shows the HeaderTemplate. I also did try with a pagelist and that one did not show the header if the list was empty, but instead pagelist doesn’t have SelectedItemTemplate. So is there any way to get both hidden header if there is no data and SelectedItemTemplate if there is something selected?
#12976
Mar 22, 2007 15:35
You could try the MenuList. There you have a SelectedTemplate and the Header should not be visible if there is no result.
#15193
Mar 22, 2007 16:24
Thanks! So easy something’s can be if you know how to do it, works just perfect. :)
#15194
Mar 23, 2007 14:42
