PageSearch an Index Server
Hi, I'm having problems searching for documents with PageSearch and Index Server. I would like the PageSearch control to search filenames as well as content. I can, however, not get this to work. In index server I can do the following query: @all *filename* This will search all properties and generates the correct result. However if i run the same query with PageSearch.SearchQuery it only returns the documents that contains "*filename*". Is it possible to enable search on filenames with PageSearch? Also is it possible to make it return all results (*)? Thanks in advance! Pontus
#13305
Dec 19, 2007 11:23
