PageRank not available when using Pagesearch and Datasource
Hi all, I'm trying to perform a searchbased on a datasource - instead of a Pagelink , see code below: The result is correct, except that PageRank not is available, I'm using ' Container.CurrentPage["PageRank"]' in the ITEMTEMPLATE. However - if I use the pagelink instead - Pagerank is available , see code below: My question is : Why is PageRank not available when using Pagesearch and Datasource ??? (The reason for using datasource instead of pagelink is that I want to search 4 different areas of the site - and not from the root) Kind regards Morten Steensgaard
#13225
Oct 03, 2007 14:34
