EpiGoogleSitemaps language problem
Hi! I'm using EpiGoogleSitemaps on a 4.61 site. It generates a XML-file, but the URLs gets an extra folder in the path, /EN/. This is wrong, because the site is only in Swedish and none of the URL:s has got this /EN/ in the path. I've turned of the Globalization setting in Admin, but still I get this extra /EN/. Has anybody the answer for how to get rid of this? /Jan Back
#13243
Oct 19, 2007 11:02
There is two versions for the EpiGoogleSitemaps. One with multi language and one "normal". Make sure you have the right one. And make sure you've installed your site with the correct default language.
#15547
Oct 29, 2007 16:57
