Error loading schemas
In the file: C:\Program Files\EPiServer.IndexingService\Logs\LogServerError.log I get the folloving error: 2007-01-22 11:35:52,034 [2220] EPiServer.IndexingService.ConfigurationHandler.Create(:0) - Failed to setup configuration: Error loading schemas Exception: EPiServer.BaseLibrary.ObjectStoreException Message: Error loading schemas Source: EPiServer.Implementation at EPiServer.Implementation.SqlObjectStore.get_Schemas() at EPiServer.Implementation.DefaultRepository.RegisterSchemasFromStore(IObjectStore store) at EPiServer.Implementation.DefaultRepository.InitializeSchemas() at EPiServer.IndexingService.ConfigurationHandler.Create(Object parent, Object configContext, XmlNode section) Nested Exception Exception: EPiServer.BaseLibrary.ObjectStoreException Message: Error opening connection. Source: EPiServer.Implementation at EPiServer.Implementation.SqlObjectStore.OpenConnection() at EPiServer.Implementation.SqlObjectStore.get_Schemas() Nested Exception Exception: System.Data.SqlClient.SqlException Message: General network error. Check your network documentation. Source: .Net SqlClient Data Provider at System.Data.SqlClient.ConnectionPool.CreateConnection() at System.Data.SqlClient.ConnectionPool.UserCreateRequest() at System.Data.SqlClient.ConnectionPool.GetConnection(Boolean& isInTransaction) at System.Data.SqlClient.SqlConnectionPoolManager.GetPooledConnection(SqlConnectionString options, Boolean& isInTransaction) at System.Data.SqlClient.SqlConnection.Open() at EPiServer.Implementation.SqlObjectStore.OpenConnection() Any one has any idea what's wrong? Regards Per
#12904
Jan 22, 2007 12:26
General network error. Check your network documentation. Source: .Net SqlClient Data Provider at System.Data.SqlClient.ConnectionPool.CreateConnection() Indicates that the credentials supplied isn't allowad to logon to the sqlserver. /HAXEN
#15073
Jan 23, 2007 18:04
