Convert to XForms
Hey I try to convert forms to xforms using the "Convert form". But I get this error message: [XmlException: The '=' character, hexadecimal value 0x3D, cannot be included in a name. Line 5, position 38.] System.Xml.XmlTextReaderImpl.Throw(Exception e) +87 System.Xml.XmlTextReaderImpl.Throw(String res, String[] args) +77 System.Xml.XmlTextReaderImpl.Throw(Int32 pos, String res, String[] args) +18 System.Xml.XmlTextReaderImpl.ParseElement() +693 System.Xml.XmlTextReaderImpl.ParseElementContent() +461 System.Xml.XmlTextReaderImpl.Read() +26 System.Xml.XmlLoader.LoadNode(Boolean skipOverWhitespace) +557 System.Xml.XmlLoader.LoadDocSequence(XmlDocument parentDoc) +50 System.Xml.XmlLoader.Load(XmlDocument doc, XmlReader reader, Boolean preserveWhitespace) +162 System.Xml.XmlDocument.Load(XmlReader reader) +96 System.Xml.XmlDocument.LoadXml(String xml) +194 EPiServer.Admin.ConvertFormToXform.ConvertForm2Xform(Int32 formId) +281 EPiServer.Admin.ConvertFormToXform.Convert(Object sender, EventArgs e) +252 System.Web.UI.WebControls.Button.OnClick(EventArgs e) +105 System.Web.UI.WebControls.Button.RaisePostBackEvent(String eventArgument) +107 System.Web.UI.WebControls.Button.System.Web.UI.IPostBackEventHandler.RaisePostBackEvent(String eventArgument) +7 System.Web.UI.Page.RaisePostBackEvent(IPostBackEventHandler sourceControl, String eventArgument) +11 System.Web.UI.Page.RaisePostBackEvent(NameValueCollection postData) +33 System.Web.UI.Page.ProcessRequestMain(Boolean includeStagesBeforeAsyncPoint, Boolean includeStagesAfterAsyncPoint) +5102 Anyone who know something about this problem? I'm running on Episerver v.4.61.0.83 (.NET Framework 2.0)
#12890
Jan 08, 2007 10:28
