Create a new page when publishing another
Hi. I'm trying to create a page when publishing another. The new page is supposed to be set with the same pagetype, and with the "Fetch Data from" set on. I'm using EPiServer 4.60. I've discovered that I need to set the newPage.LinkType = PageShortcutType.FetchData. But where do I go from here? I try to set the PageLink property to point to the original page, but this results in that I'm actually editing on the original page, and the new page never gets created. Anyone got a tip? Frank :)
#12787
Sep 21, 2006 22:49
The two properties you want to set would be PageShortcutType and PageShortcutLink. For example if you were doing this in the DataFactory PagePublished event you could do the following. if (e.Page.LinkType != PageShortcutType.FetchData) { PageData newPage = Global.EPDataFactory.GetDefaultPageData(e.Page.ParentLink, e.Page.PageTypeID); newPage.Property["PageShortcutType"].Value = PageShortcutType.FetchData; newPage.Property["PageShortcutLink"].Value = e.PageLink; Global.EPDataFactory.Save(newPage, EPiServer.DataAccess.SaveAction.Publish); }
#14901
Sep 22, 2006 1:23
Thanks! That did the trick. Frank :D
#14902
Sep 22, 2006 7:50
