still having problem with subscription function
I'm using the standard komponent for subscription. It works fine until the mail should be sent, then I get this message: The job failed: Exception has been thrown by the target of an invocation. [Could not access 'CDO.Message' object.] Does somebody knows whats wrong?
#12663
Jun 02, 2006 10:47
Do I have to install the SMTP-service on the IIS-server?
#14703
Jun 02, 2006 11:21
No, you can use any smtp-server. Add the server and port in EPiServer Manager.
#14704
Jun 07, 2006 10:31
I´m new with Episerver. What do you meen by adingin the sever and port in EPiServer Manager?
#14705
Jun 08, 2006 9:16
There are web.config settings to configure the SMTP server used by some EPiServer functionality. You can set/modify these values in two ways: 1) Editing the web.config file manually (in some text editor). 2) Using the EPiServer Manager software. The settings are named EPsSmtpServer, EPnSmtpServerPort, EPsSmtpUser and EPsSmtpPassword. Using the EPiServer Manager, find your web site in the left hand pane, expand it, select "Web.Config" and scroll down a bit on the General tab.
#14706
Jun 14, 2006 13:14
