private static int Level(PageData aPage)
{ return aPage.Indent; }
Have you tried using that, and failed?
protected void Application_Start(Object sender, EventArgs e)
Global.EPDataFactory.LoadedPage += new EPiServer.PageEventHandler(EPDataFactory_LoadedPage);
void EPDataFactory_LoadedPage(object sender, EPiServer.PageEventArgs e)
// Find and cache the indent
if (HttpContext.Current != null && e.Page != null)
int pageIndent = 0;
string key = "IndentCache_" + e.Page.PageLink.ID.ToString();
object cachedIndent = HttpContext.Current.Cache[key];
if (cachedIndent != null)
System.Diagnostics.Debug.Write("Indent from cache");
pageIndent = (int)cachedIndent;
else
// Find and store indent
pageIndent = Level(e.Page);
// Store in cache, with dependency to the global
// EPiServer cache, to handle moving pages etc.
StorePageIndentInCache(key, pageIndent);
System.Diagnostics.Debug.Write("Indent stored in cache");
e.Page.Indent = pageIndent;
private int Level(PageData aPage)
int iLevel = 0;
if (aPage != null)
PageReference parentReference = aPage.ParentLink;
while (parentReference != PageReference.EmptyReference && parentReference != Global.EPConfig.RootPage)
parentReference = Global.EPDataFactory.GetPage(parentReference).ParentLink;
iLevel++;
return iLevel;
private const string KEY_CACHE_PAGEINDENT_DISABLE = "EPfDisableCaching_PageIndent";
/// Adds the PageIndent to the cache, with a dependency to the global EPiServer
/// page cache.
private static void StorePageIndentInCache(string uniqueCacheKey, int pageIndent)
// Check if caching is disabled - can be for debugging or troubleshooting
// Because of the "EPf" prefix, EPiServer will convert this
// to a bool. Returns true if value is true, if not, returns false.
// Also returns false if the key does not exist, or there is some
// error parsing it as a bool.
if ((bool)Global.EPConfig[KEY_CACHE_PAGEINDENT_DISABLE] == true)
return;
// Make the cache dependent on the EPiServer cache, so we'll remove this
// when new pages are published, pages are deleted or we are notified by
// another server that the cache needs refreshing
String[] pageCacheDependencyKey = new String[1];
pageCacheDependencyKey[0] = DataFactoryCache.VersionKey;
CacheDependency dependency = new CacheDependency(null, pageCacheDependencyKey);
// Add to cache, without dependencies and expiration policies
// If the cached item should be cached for limited time (regardless of
// the cache dependency), add an absolute expiration date or a
// sliding expiration to the item.
// Also note, we use the Insert method that will overwrite any existing
// cache item with the same key. The Add method will throw an exception
// if an item with the same key exists.
HttpContext.Current.Cache.Insert(uniqueCacheKey, pageIndent, dependency);
You can monitor the effect of this by using DebugView from SysInternals. It takes a little time, but after a while you should only see lines like this:
"Indent from cache"
/Steve
private static int Level(PageData aPage) { int iLevel = 0; if (aPage != null) { PageReference parentReference = aPage.ParentLink; while (parentReference != PageReference.EmptyReference && parentReference != Global.EPConfig.RootPage) { parentReference = Global.EPDataFactory.GetPage(parentReference).ParentLink; iLevel++; } } return iLevel; }So - Help please! How can I write this code better - or should I go and write a SQL Stored proc to do it for me quicker? Thanks folks - love your work. Cameron
