Asp.net StateServer vs the default In-process
Hi! Does anybody know if EPiServer can run with the asp.net stateServer instead of the default In-process (since items must be serializable etc)? Can't find any documentation on this subject. Additional: How much does EPiServer use session? EPiServer recommendations?
#12626
May 10, 2006 9:39
EPiServer does not use the Session object (I'm pretty sure). My recommendation is that neither do you. I know that it can be difficult to avoid, but if EPiServer can run without, everything is possible. Btw, search Microsoft Knowledge Base about the different session stores, there are issues on object serialization that differs based on the location. /Steve
#14623
May 10, 2006 21:33
