Mirroring files
Does anybody know if files and documents are copied along with pages when mirroring is used? Does mirroring include the page-specific documents, all documents or none of these?
#12588
Apr 10, 2006 18:39
Mirroring will mirror attached files if they are linked in a property using standard functionality. E.g. If you link a document into the main body content of a page using the insert document tool, the the linked document will be mirrored. The linked files must be in a UnifiedFileSystem share, such as Page files or Global files etc. If you have a dynamic control that lists files from a UnifiedDirectory at runtime, then mirroring will not mirror these files, they have to be linked into a property. One other note, last time I checked there was a bug in mirroring where the file summary information saved in EPiServer for a file is not mirrored, even when the file is. -- Jeremy
#14550
Apr 11, 2006 5:02
Thanks! I will check with the client but I think we will have to set up something like rsync for the UnifiedDirectory, which means it won't use the new (from 4.50) and version controlled functionality.
#14551
Apr 11, 2006 9:42
Be aware that there's a really annoying bug with the document mirroring. The picture URLs are not changed when you mirror document pages. (or do an export/import) If your customer uses excel to display charts etc., or pictures in word documents, I would wait until there's a fix available.
#14552
Apr 24, 2006 10:13
Besides that, mirroring of documents works great...
#14553
Apr 24, 2006 10:14
