Is it possible to have several items expanded when using the PageTree control?
Is it possible to configure/code so that have several items expanded when using the PageTree control? /Lars
#12575
Apr 05, 2006 9:17
Try this property. EPiServer SDK Reference PageTreeData.OpenPages Property /HAXEN
#14534
Apr 06, 2006 8:14
OK, I will try that one. Im struggling to create the following: I want to create an menu that looks like the tree in windows explorer, i.e with minus/plus signs for expanding levels, but without the dotted lines. What is best, use the ExplorerTree control and modify or use the PageTree control and modify to use the plus/minus symbols instead of the arrows, and make these clickable? /Lars
#14535
Apr 06, 2006 11:06
I've used the WebTree from http://www.infragistics.com in one installation instead of the regular implementation of categories, 500 categories requires another GUI. I found it easy to implement and it looks great. /HAXEN
#14536
Apr 06, 2006 22:44
Sorry NOT infragistics! http://www.componentart.com/treeview/default.aspx Is the one I used. /HAXEN
#14537
Apr 06, 2006 23:15
Håkan Alexander, do you have an example on how to load the componentart treeview control within an EPiServer environment? Thanks /Lars
#14538
Apr 26, 2006 10:22
