EPiServer Scheduler Service
Is it possible to config EPiServer to write to the eventviewer if a job has Status FAILED. /Tomas
#12596
Apr 12, 2006 15:49
I would say Yes. If you use EPi v 4.50 or later alot of events is written to the logsystem. Information about logs build in to the system can be found in this TechNote. http://www.episerver.com/downloads/Documents/TechNotes/EPiServer%204.51/Logging%20in%20EPiServer.pdf And information about how to redirect event messages to the windows eventlog can be found here. http://logging.apache.org/log4net/ Please publish your result here when you've found out how to, or if you have more questions I will try to help more. /HAXEN
#14565
Apr 18, 2006 21:44
Hello, This could help us. We are using MOM and I think it's possible to config MOM to check the EPiServerLog\Monitor folder for errors and new messages. /Tomas
#14566
Apr 19, 2006 16:17
