other multi language features
Hi, I've managed to get the multi language features to work, but want to know if the following is possible: 1. If my website uses 3 languages; English, French and German; the tabs (edit mode) displays the languages in alphabetical order. Is it possible to change the order? 2. The publish start and end date resides under the "Common" tab. Is it possible that have the publish start and end date on each of the language tabs instead of the "Common" tab? Kind regards, Danie
#12547
Mar 13, 2006 17:01
1. Yes, but you need to convert/upgrade to the new globalization support in EPiServer. 2. Same answer as above.
#14479
Mar 14, 2006 12:57
Hi ! Thanks for your reply. Is this an upgrade/conversion to a new version of Episerver ? Thanks, Danie
#14480
Mar 14, 2006 14:06
EPiServer 4.60 with a fully integrated globalization support was released last friday. Please contact our support if you want to convert old multi language content.
#14481
Apr 03, 2006 15:38
