selector framework
(This content was manually imported after an update to www.episerver.com)
selector framework
selector framework region content..... framework region content.... OR selector framework region control with content framework region control with content
My content for framework 1
My content for framework 2
The EPiServer Content web control cannot be put inside a user control, it has to be the first control inside a framework in the .aspx page. The content inside the content control can be a user control, if you'd like that.
If your content contents look almost the same for different frameworks, you might want to see if dynamic properties and making the default framework "smarter" will do the same trick as changing framework on the fly.
I've seen solutions that loads user controls (headers, footers etc.) on the fly based on values from dynamic properties.
/Steve
This means that you do not need a printer friendly button of any type. The design applied using the media=print styles should make the design horizontally scalable, then it will adjust to the paper witdh (which is the typical problem.) The stylesheet should also hide all elements that you do not want to print. Beware of background colors and images, as the default print settings in IE skip these.
Btw. you could keep that "Print" button there, and just do a window.print. Technical people know that web design seldom print very well, and is looking for that button to make sure they get something printable.
There is a lot of good resources on this topic on the web, happy hunting! :-)
/Steve
As stated in the text on the sample page, the framework is set with the help of a dynamic property.
Frank :)
