ExpandedItemTemplate in PageTree
I can't get the ExpandedItemTemplate/SelectedExpandedItemTemplate to work properly in PageTree. Expanded (second level) items are always rendered as ItemTemplate or SelectedItemTemplate. Is this a bug or a feature ;) /René
#12557
Mar 17, 2006 16:01
If I remember right there is a bug when you hava a page open under the last level shown in the PageTree then the last level vill not be treated as expanded even though that would be logical. There used to be a PageTree control among the sample's but I couldn't find any more, well from that I think there was only a tiny change that was needed to correct that problem. Dono if your problem is the same, but send a mail to the support and let us all know the answer! /HAXEN
#14504
Mar 19, 2006 22:00
I have the same problem. Did you find a solution for this? BR, Erik
#14505
Jul 18, 2006 12:39
