Could someone point me in the correct direction to understanding why the following is happening and how to avoid it please?
I'm writing an Admin plug-in and would like to add an ExplorerTree control. I copied the example from Developing Solutions with EPiServer, modifying it as I assume that there is no CurrentPage so I need to sort out my own PageReference instance for the Pagelink property:
I also tried:
PageLink="<%# new episerver.core.pagereference35>"
and setting the PageLink just before DataBind in the code-behind file.
All of which give me the same error:
EPiServer.WebControls.PageTreeData.PopulatePages(PageDataCollection pages) +250
EPiServer.WebControls.PageControlBase.ᐁ() +44
EPiServer.WebControls.ExplorerTree.Render(HtmlTextWriter output) +51
Also tried setting PageLink in the code behind file to no success.
Does anyone have a working sample of using ExplorerTree that would function correctly in an Admin plugin?
I'm using ASP.NET 1.1, EPiServer 4.60 on XP.
Cheers,
Andy
