EPiServer:Calendar and PropertySearch
Hi, I need to to a property search to fetch calendar events from different parts of our website and then bind the results to a EPiServer:Calendar control. However, I'm unable to do this. No results show up. The strange thing is that when I use a PageList instead with exactly the same datasource, the events shows up on that one but not the Calendar. When I use the example code below, only the list rendered by the PageList shows up: Does anyone know what the problem might be? Isn't it possible to bind PropertySearch results to other controls than PageList, like the Calendar? Thanks / Christoffer
#12859
Dec 04, 2006 16:39
