Changing upload folder using Unified File System
Hi. We are having some problem changing the filepath for the upload folder. We are using Unified File System. We have many files in the file archive and many of them have been used in articles in the web solution. Is it possible to create a new virtual share, copy the files from the old virtual share to the new virtual share, edit the filepath in the web.config, and then everything should work as it did? The old handler looks like this: The new handler looks like this: Is it something special we need to think about when we do this? Access rights for example? BR, Tore
#12862
Dec 07, 2006 10:35
You will have to change URLs to files referenced/linked in any editor because of the new path. And you will have to set upp access rights for the new location. /HAXEN
#15014
Dec 11, 2006 9:35
