ExpandAll && NumberOfLevels
Hi, I'm building a menu, based on EPiServer's PageTree. I want to have two levels of menu expanded. Here is an example: menu 1 menu 1.1 menu 1.2 menu 2 menu 2.1 menu 2.2 menu 3 menu 4 In my understending it should be enough to set properties ExpandAll and NumberOfLevels to let the control (PageTree) render as I showed in an example. Unfotunatly it is not working in that way, at least in my solution. It is rendering like that: menu 1 menu 2 menu 3 menu 4 My questions are: - do I not understand (guss from names) properties ExpandAll, NumberOfLevels - Mybe I miss smth, and any of you has any suggestions what mightbe the reason. Thanks in advance for any suggestions Regards, Piotr Sendor
#12831
Nov 14, 2006 14:09
