Default directory sample not working properly
Hi, I was trying the "Changing default directory based on dynamic property" from code samples but can't get it to work properly. What I have done: 1. Change the Global.asax.cs and recompiled 2. Create the dynamic property "DefaultUploadDirectory" of type string 3. Create the folder "/upload/test" 4. Set the dynamic property "DefaultUploadDirectory" to "/upload/test" on a subpage to the startpage The whole thing works in the "File manager" but when I go via "Insert document" the ordinary global folder is showing up.
#12382
Sep 30, 2005 10:02
It's the same control that renders both GUI's so it should be no difference, make sure you do not select an existing document/image before opening the "Insert document", otherwise the default directory will be the currently selected file's directory.
#14165
Oct 03, 2005 9:17
I have even tried it with a new empty page but the problem still remains.
#14166
Oct 03, 2005 10:44
Even if there shouldn't be a difference there is one as I'm still not able to use this function in "Insert document". Any help is highly appreciated.
#14167
Oct 11, 2005 14:48
