How do I configure a separate web application to run on the same server?
EPiServer is installed in the root and I would like to have other applications on the same server/domain. But when I try to run them I get Server Error: Line 74: Line 75: I've created a new application and changed the web.config to: But I still get the same error message. Is there a way have other web applications to run on the same server/domain?
#12301
Jun 17, 2005 10:31
Even do you try to clear the httpModules section, you still have to copy all of the episerver dll's to the bin catalog in your application. Frank :)
#14026
Jun 20, 2005 9:28
I have done it and it works perfectly. In the application's web.config I had to override each division used by EPiServer, like system.web, runtime, location and appsetting. I also copied the application's dll to the root's bin catalog. Regards Christian
#14027
Jun 21, 2005 11:27
