Create Soft links in tblPageSoftLink
Hi, I am upgrading a EPiServer 3.3 solution to EPiServer 4. The problem is that I need to convert inline links (creatad in editor) that concerns the old page templates. I have created a script that converts all soft links in column longstring of table tblProperty. I found about 5000 occurances. The table tblPageSoftLink does not contain all these links. It only contains among 200. It might be due to the fact that this function has not been present until version ??? of EPiServer. My question is: Is there any script available to recreate the tblPageSoftLink? Thank you. /Sofia
#12247
Mar 22, 2005 12:17
Dont know if you alreadu solved this. What I did was to use the search-n-replace tool posted on the site and modified it to accept Regular Expressions/patterns. Worked like a charm... /Jonas
#13917
May 17, 2005 10:17
