Changing ?id= to ___id.aspx
Hi, How do I change the URL from ex. xxx.aspx?id=999 to xxx____999.aspx? /Lea
#12476
Dec 21, 2005 9:04
You can change the type of links in the admin mode. Under System administration/Robot search select the radio box "Use links that allow search engines to crawl the website". This will change you site to use xxx___999.aspx instead of xxx.aspx?id=xxx. // Isabel
#14337
Dec 21, 2005 9:38
