rebuilding Epistore
Hi, I'm evaluating episerver and have run into a bit of a show stopper. I've installed epistore onto episerver and everything works fine, the front-end and admin both work as they should. The problem I have is that the currency symbol is after the value, no problem, a simple code change and that's fixed, then I tried to rebuild the project and it started spitting out errors. Do I need to change by basic setup to get this to rebuild (I have used pretty much all the default settings) or have I missed something? thanks!
#12455
Nov 29, 2005 15:27
fixed now. I was missing a couple of references, once added, it worked fine.
#14289
Nov 29, 2005 16:25
