Customizing the FormData-page
When you view records that has been posted to a forms-page there is an option to select the number of records that should be displayed on screen. However, when hitting the Delete-button all records are deleted, not just those being displayed. Is there a quick'n easy way to delete only those being displayed? That way I'll be able to remove older records, and still keep the newer ones. Frank
#12418
Nov 01, 2005 9:15
Hello Frank! I admit that the behaviour that you describe is a bit more intutative. If you want to do this today you can set the start date and the stop date to the first and last post that you want to delete and redo the search. I added the following request: Issue #41602 - Deletion of form posts should only delete the posts currently visible.
#14232
Nov 01, 2005 10:38
