Table property's popup window to small
A single user (with latest service packs and IE) is experiencing problems with table propertys popup windows in edit mode. The window is not sized properly and the user cannot see all buttons etc.. I know this is probably not an EPiServer error but maybe someone here has experienced the same problem? //Jocke
#12385
Oct 04, 2005 9:29
Check the DPI setting under advnaced settings in display options. If it's larger then normal (96 DPI) errors similar to that can occur.
#14169
Oct 04, 2005 11:51
This solved this issue, thank u Per for the response...
#14170
Nov 07, 2005 9:53
