Remove language attribute from HtmlInputButton
Hi! I'm working with an EPiServer web site that needs to conform with XHTML 1.0 Transitional and got an ASP.NET HtmlInputButton which automatically adds the attribute language="javascript" which isn't allowed in XHTML. I've tried to remove this attribute by executing QuickSearchButton.Attributes["language"] = ""; or QuickSearchButton.Attributes["language"] = null; or QuickSearchButton.Attributes.Remove("language"); in either Page_Load or QuickSearchButton_PreRender, but it does not work. I can add a new custom attribute, so I know that I can access the control. I found some postings about using a filter when outputting the response stream, but that seems to be overkill for just this issue. Before I start hacking away, I have some questions: 1. Is it possible to build the control entirely from code-behind without a language attribute ? 2. Could I perhaps use .RenderControl and filter the output there? 3. Is there any other way to accomplish this? Brgds Jonas
#12152
Oct 21, 2004 11:20
